| WebTuga - Comunidade Nacional Web 2.0 | |
| Ver mensagem anterior :: Ver mensagem seguinte |
| Autor |
Mensagem |
agfrg mod
Idade: 15 Registrado em: 28 Mai 2006
Especificação:
Mensagens: 3559 Local/Origem: Somewhere behind a localhost
Colocada: Sáb Mai 17, 2008 7:17 am Assunto: [Tutorial] Fonte Estabilizada de 5V para Hub USB (Inglês) |
| Citação: | This is a stabilised supply intended to be used with a bus powered USB hub in order to deliver a stabilised + 5 volt supply to the devices connected to it.
Due to the resistance of the connecting cable, and the resistances introduced for current sensing for overcurrent protection, the voltage at the hub can be anywhere between +4.5 V(loaded) and +5.5 V. This circuit will deliver a stabilized +5 V in both the cases, ie, it is a buck/boost design, using the TPS63000 switch mode regulator chip manufactured by Texas Instruments.
It can deliver +5 V at 500 mA from input voltages as low as 2 Volts so a rechargeable battery and its (USB powered) charger can be added to make this into a USB UPS for the USB hub. |
LINK: http://www.instructables.com/id/5V-stabilised-supply-for-USB-hub/ |
| Voltar ao topo |
Neste fórum, você Não pode colocar mensagens novas Não pode responder a mensagens Não pode editar as suas mensagens Não pode remover as suas mensagens Você Não pode votar neste fórum
Powered by phpBB © 2001, 2002 phpBB Group
iCGstation v1.0 Template By Ray © 2003, 2004 iOptional
